Dzhelebov's 2018 L&K 2.0TDI 190cv 4x4 7DSG
Dzhelebov
Гараж: Skoda Superb 2018 2.0TDI 190cv 4x4 L&K 7DSG
Мнение от Dzhelebov »
Мисля, че няма такава опция.
Dzhelebov
Поразрових малко из нета и попаднах на следното инфо
Някой пробвал ли е подобно нещо за да реши проблема с Андроид Ауто и изчезването на клавиатурата докато колата е в движение?
I can confirm that the steps below disable of the these massages and allow input for phone numbers, destinations in NAV and viewing test messages while the car is in motion.
5F-Information Electr.
Adaptation-10
Starting at Channel IDE11502-FB_CAR_0, change anything ‘blocked’ to ‘non_blocked’
Starting at Channel ENG167428-nhtsa_properties-limitation_dependency, change all android and apple to ‘non_blocked’
To be more fulsome:
IDE11502-ENG1276xx-Locked menu contents-FB_CAR_x
ENG167428-ENG1675xx-nhtsa_properties-limitation_dependency
the xx above means that there are multiple "Child" channels associated to the "Parent" channel names (being the descriptor immediately after the "-" following the Tag numbers.
So - try entering "FB_CAR" into the search box for the first group of channels - and "nhta_properties" for the second group.
А ето ги и кодовете от темата:
IDE11502-ENG127601-Locked menu contents-FB_CAR_0
IDE11502-ENG127602-Locked menu contents-FB_CAR_1
IDE11502-ENG127611-Locked menu contents-FB_CAR_10
IDE11502-ENG127612-Locked menu contents-FB_CAR_11
IDE11502-ENG127613-Locked menu contents-FB_CAR_12
IDE11502-ENG127614-Locked menu contents-FB_CAR_13
IDE11502-ENG127615-Locked menu contents-FB_CAR_14
IDE11502-ENG127616-Locked menu contents-FB_CAR_15
IDE11502-ENG127617-Locked menu contents-FB_CAR_16
IDE11502-ENG127618-Locked menu contents-FB_CAR_17
IDE11502-ENG127619-Locked menu contents-FB_CAR_18
IDE11502-ENG127620-Locked menu contents-FB_CAR_19
IDE11502-ENG127603-Locked menu contents-FB_CAR_2
IDE11502-ENG127621-Locked menu contents-FB_CAR_20
IDE11502-ENG127622-Locked menu contents-FB_CAR_21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22
IDE11502-ENG127624-Locked menu contents-FB_CAR_23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3
IDE11502-ENG127605-Locked menu contents-FB_CAR_4
IDE11502-ENG127606-Locked menu contents-FB_CAR_5
IDE11502-ENG127607-Locked menu contents-FB_CAR_6
IDE11502-ENG127608-Locked menu contents-FB_CAR_7
IDE11502-ENG127609-Locked menu contents-FB_CAR_8
IDE11502-ENG127610-Locked menu contents-FB_CAR_9
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad
zalmaneca
Гараж: Superb 3 FL 2.0TDI 190 L&K
Мнение от zalmaneca »
Dzhelebov написа: 26.04.2021, 16:54:07 проблема с Андроид Ауто и изчезването на клавиатурата докато колата е в движение?
То не е проблем.
Това така трябва да бъде.
Dzhelebov
Да, прав си колега, но е изнервящо и ако може да се махне аз бих го махнал.
Малко като със старт-стоп системата, която много хора искат да изкоренят, аз искам да изкореня тази защита за писане по време на движение, защото според мен е доста по-опасно да взема телефона в ръка и да пиша на него, от колкото да натисна няколко пъти по големия екран на колата.
HerpaMoTeH
Гараж: Skoda Octavia III combi 1.4tsi DSG
Мнение от HerpaMoTeH »
Dzhelebov написа: 26.04.2021, 17:31:57 защото според мен е доста по-опасно да взема телефона в ръка и да пиша на него, от колкото да натисна няколко пъти по големия екран на колата
А не е значителни по-лесно и безонпасно просто да си говориш на телефона [smilie=sarcastic.gif]
Dzhelebov
Не става, защото пак трябва да взема телефона, да му махна кабела, да вляза във приложението, да му говоря, то да намери аз да избера от резултатите, и пак да му сложа кабела (особено трудна операция докато карам). Войс командите на колата са безсилни при уейз.
Може и аз да изтървам нещо, което вие да знаете, ако е така споделете, защото е много дразнещо да трябва да спра за да въведа адрес.
Даже ще дам примерна ситуация:
1. Карам и говоря по телефона (блутут в колата)
2. По телефона ми казват адрес, на който трябва да отида
2.1 ако можех да въвеждам директно докато карам направо бих въвел на дисплея на колата и всичко щеше да е топ
2.2 След като не мога да въвеждам, трябва да запомня адреса, да спра някъде и така да го въведа и тогава да тръгвам пак, а не винаги има удобно място за спиране, а и си е дразнещо да спра само за да въведа един адрес.
3. Преди, като ми беше просто Уейз на телефона (без да го свързвам към колата) натисках микрофончето, казвах адреса и воаля - карам си към дестинацията, но сега и гласовите команди не работят, а и през андроид ауто гласовите команди трябва да са на английски през търсачката на гугл, която никога не намира нищо като адреси или ПОИ, докато на уейз на телефона директно гласовото търсене си е с негова търсачка, която работи прекрасно на български език, намира всички адреси без грешка.
Monky
Мнение от Monky »
Между точка 2.1. и 2.2. следва да добавиш 2.1.1. Удряш се някъде, защото не гледаш пътя, а екрана.
Dzhelebov
Monky написа: 27.04.2021, 13:31:50 Между точка 2.1. и 2.2. следва да добавиш 2.1.1. Удряш се някъде, защото не гледаш пътя, а екрана.
Пасажера до мен иска да въведе адрес.... Сега окау ли е?
Няма нужда от заяждане колега, 90% карат без колани и с превишена скорост, нека не изпадаме в ненужни подробности. Въпроса беше как да да се направи така, че да може да се пише адрес във уейз (не от шофьора) в движение.
Dzhelebov написа: 27.04.2021, 13:37:46 се пише адрес във уейз
Има гласово.Казваш си адреса на чист български и ти го намира.Не напразно е забранена клавиатурата в движение [smilie=pardon.gif]
Dzhelebov
igeorgiev82 написа: 27.04.2021, 14:26:30 Има гласово.
Ако говорим за това гласово то на мен ми се включва гласовото на гугл а не това на уейз, и от там ми идват главоболията, защото гласовото на гугл не разбира нищо [smilie=dash1.gif]
Ако ли пък има вариант да се пуска от там гласовото на уейз то бирите са от мен!
